R
romroms
i live in the UK and i have wanadoo broadband (orange broadband) it ca,e with a pack that had the speedtouch 330 which is USB powered and 1 ADSL filter i have conected every thing up correctly with the phone going into ADSL filter and a ethernet cable going into the modem from the ADSL filter it has been working fine for ages but now i want to connect using ICS as i dont want to buy a router i have recently gone on the xbox live guide and has done everything correct up to the IP adress part when i go on that part it just says IP adress its suposed to say subnet mask and default gateway i am just wondering if i would still be able 2 connect to xbox live plus i have enabled ICS plz reply sum1 !!!!!!!!!!!!!!!!!!!!!!!!
