Xbox live help with speedtouch 510v4 router
Discussion in 'Xbox Forums' started by captaineyecatch, May 16, 2003.
  1. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Just got my adsl activated with Zen. I plugged in the Speedtouch and it all seems to be working fine on my pc (i didnt change any of the settings on the speedtouch? - it seems to work straight out of the box)
    I'm now trying to get Xbox live working but no luck it comes up with a message about unable to find DNS - how do i set it up so it will work on xbox live?
  2. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    Zen should have given you the details of their DNS in the technical email they send you.
    can't remember needing to put it in Xbox though, but I spose you do.
    If you get really stuck, let us know and I'll revisit my xbox and zen settings.
  3. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Thanks - got it sorted just needed to switch the speedtouch off and then on and the xbox live works?? Just spent 3hours playing Ghost recon - Superb game - just need to get some XBL Friends:D
  4. mr chadwick
    mr chadwick
    put me on your friends list mate.recon is my fav xbl game.ill hook up with you sometime on there.
  5. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
  6. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    if you like gr join the forums team :D
    add my gametag to your friends list on most nights:clap:
  7. colesy
    colesy
    Dec 28, 2001
    729
    +16
    you can add me if you like.
    Have a look at www.teamcompete.com.
    Our team name is avfourumsuk.
    Del is the captain.
  8. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    colesy and derekrcross
    See you there :hiya:
    I'll check out the teamcompete site and the avforums team - thanks
  9. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Just tried to join the teamcompete but got a disc error after submitting my details - now when i try and re submit it says my gamertag is in use :( :confused:
  10. colesy
    colesy
    Dec 28, 2001
    729
    +16
    captain,
    i have checked and your are listed on the site. Maybe if you PM delav he can send you an invite.
