Xbox Live - Ethernet Hub ???
Discussion in 'Xbox Forums' started by jerkyboy, May 19, 2003.
  1. jerkyboy
    jerkyboy
    I currently share my Broadband connection with my Xbox and my PC and was wondering if an Ethernet Hub would save me the hasstle of swapping the leads around each.
    I know a Router would solve the problem, but I dont need to use both the Xbox and PC at the same time so I dont really want to spend the money.
    Any help would be appreciated.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    You will need a router, a hub is not really a gateway device as it does not usually provide NAT nor DHCP (what a routers main job is).
    A hub would allow your PC and X-Box to speak to each other, but not to use a gateway like your ADSL modem. You could buy a cheap router, which allowed you to plug in an ADSL modem.
  3. jerkyboy
    jerkyboy
  4. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
  5. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Typhoon, im probably blind but that link doesnt appear to have an routers on it. Mainly dimms etc
    Matt
  6. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Manic Im sure jerkyboy has the intelligence to put adsl modem router in the search box what do you think tried to redo link but still only goes to the same page for some strange reason
  7. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
  8. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    :clap: wOOHOO Yep that works a treat.
    U got Toca yet Typhoon??
    Matt
