Xbox Live - Dissapointed
Discussion in 'Xbox Forums' started by jerkyboy, Nov 19, 2003.
  1. jerkyboy
    jerkyboy
    I've had Xbox live now for over six months and I have to say that overall I am pretty disapointed with the performance.
    I have been playing games for a while over the years with my PC just using a crappy 56k dial up modem. I can honestly say that using my Xbox with Telewest Braodband is not much smoother than my Dial up Days.
    Most games suffer from some sort of Lag, the latest being Top Spin which often is unplayable due to the delay after pressing a button to play a shot,its ridiculous.
    Moto GP 2, usually has one or two bikes flying all over the screen, Rainbow Six is far from silky smooth. The list goes on.
    I am wondering if perhaps I would be better of with BT, or do all Broadband suppliers suffer the same problems.
    Its a real Pisser, using my PC to surf the net is great, very fast. Its just not what I expected on Xbox.
    Any feedback or advice would be appreciated.
  2. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    I'd suggest changing your broadband supplier, try here for info on the better ISP's http://www.adslguide.org/. I'd recommend Nildram.
    Live should be relatively lag free.
  3. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    try not to post the same thing in two different areas mate.
    i think its against forum rules.
  4. hulkhead
    hulkhead
    Jul 2, 2002
    670
    Kent
    +11
    i have had xbox live since launch in the uk and have rarely seen any lag and i only have NTL 600k broadband connection. As speedsix says perhaps it may be a good idea to change suppliers. I would recommend xbox live to anyone as its the best laugh you can have and most of the games are top notch especially rainbox six 3, midtown madness, rtcw, grit, motogp2, crimson skies and hopefully pgr2 next week
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    No lag for me - sounds like a local issue.
  6. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Who's server are you connecting to?? many xbox live users try and host to many people - Connect to a USA server and you will suffer some lag due to the distance.
    I host a lot of the the AVforums teams (R6, Sof2, Ghost recon games) and have very little lag But i do limit the number of people on my server - 8 for Ghost recon and 10 for R6 and 12 for Sof2.
    Are you using your PC when you are on xbox live ?? as that will cause lag especially if you have Kazzalite or similar on as that eats up the upload which is what you need for xbox live.
    What sort of speed are you getting on xbox live, post it here and i'll compare it with mine. To get the speed details go to the connection screen where it says searching for DNS servers etc and connect. Once its connected press the Y button and a screen will come up with your xbox live download and upload speeds, Ping etc.
  7. Kramer
    Kramer
    Just got an -box yesterday, Live seems OK to me.
    Stats are:
    UL: 65kb, DL: 308kb, L: 181ms (187m), P: 18/25.
    Assume P is ping but what are the 2 figures for? What's L?
    Anymore info I can get see on that page?
    :smoke:
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    L is latency away from the MS auth server. But to be honest the numbers that are generated are very questionable.
    Nel.
  9. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Yes the numbers arent 100% correct/reliable but they do give you a good idea of how well the xbox live is connecting/working.
    Mine are ....(does vary a bit)
    Upload = 230
    Download = 540
    Latency = 164m (165m)
    Ping = 20/25
    Not bad for a normal 512k ADSL BB connection.
  10. -Spike-
    -Spike-
    May 17, 2001
    1,518
    E.Sussex
    +219
    Personally I wouldn't pay any attention to the MS test.
    Just go to the link that speedsix posted above and the test there is about as accurate as they come.
  11. Kramer
    Kramer
    Certainly doesn't look like the MS results are very acurate/reliable, certainly not in my case.
    Thanks for the info guys :)
  12. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    Doesn't the Ping X/X mean packet loss?
    UK live users all seem to have several packets dropped? Will have to check mine.
  13. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    Ive never had any probs with XBlive
    Though some bikes do seem to jump sometimes on motogp, I put this down to other ppls connection.
    Im with Eclipse
  14. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,473
    London
    +83
    xbl is great!
    it only lags when stupid yanks join your server.
    and then get promptly kicked out by captain!
  15. Kramer
    Kramer
    MS must have been listening - my DSL connection disappeared today.
    Nothing the ISP can do till Monday at the earliest.
    No XBL for me till then :(
  16. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I'm new to Xbox live, and though I have had incredible fun with top spin and moto gp, I have consistant problems with losing connection. On top spin it says the other person has left, and leaves me to 'win' the tie, even though I am actually getting thrashed. This means my rating is far too high as I am actually crap at it. I have had similar probelms with moto gp. Are other gamers leaving because I smell bad, or is my connection breaking down, or is theirs. It is very frustrating. I am using blueyonder, and have had lag issues on xboxlive, and most importantly consistant loss of connection. But I don't know if it is my problem. I have blueyonder for the pc, and that has been fine as far as I know, but then I don't play on line games on the pc. Should I change supplier? If anyone has been playing top spin and has never experienced lag or loss of connection, maybe you could give me a game or 2 to see if the problem goes at my end.
    Come and improve you top spin ranking, and help me out at the same time.
  17. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    What bandwidth do you buy from blueyonder?
    Neil.
  18. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    600K. Should I get more?
  19. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    No that should be more than enough. Do you have anything else
    using the internet connection at the same time your Xbox is running? Or do you have a wireless network?
    Neil.
  20. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I am using it wireless. It connects fine, and sometimes, like last night on motogp, it faultless.
    I am using a Netgear MR814 router to a ME101 bridge connected to the Xbox
  21. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Check that someone else isn't logging into your wireless network and using your bandwidth. This is becoming a fairly common issue.
    Neil.
  22. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    sorry to sound stupid....but how do I do that? I have only just fitted it a few days ago
  23. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    No idea with that equipment- check the manual - did you have the slowdown before you got the wireless network?
    Neil.
  24. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Also when you login to Live switch your PC off.
  25. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I'm a bloke!!!
  26. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    works great now, thanks Neil :clap:
  27. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    What was it? What did you do?
  28. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I turn off my pc, I assume so the Xbox doesn't get inturrupted by emails coming in etc. Smooth lag free PGR2. Awesome. Add me to your list and I'll race yer.
    And lose!:suicide:
  29. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    if you want to still use the pc while on live download a prog from www.netlimiter.com. You can set a limit of say 5kB/sec for the comp so web/email still work (similar to 56k speed wise) and live wont get intterupted.
  30. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Nice one. I'll give it a go.
    Kwijibo1 - will add you to Friends List when back on tomorrow night.
