Xbox live connectivity help!!
Discussion in 'Xbox Forums' started by dunks517, Aug 5, 2005.
  1. dunks517
    dunks517
    May 22, 2005
    4,003
    Orbiting Bono's Ego...
    +513
    :lease: Just before my Xbox goes out the window, I am trying to connect it to my laptop via an ethernet crossover cable into my laptop's ethernet port, there is ocasionally a connection of 100.0Mbps but mainly the limited or no connectivity warning can be seen. I cannot find where in the properties the ICS sharing bit is! The '1394 net adapter' has it but not 'Via compatible fast ethernet adapter' (which one is which?) I have inputted the two DNS addresses given to me by wanadoo and left the IP address, subnet mask and gateway blank and set for automatic\configuration. I have tried to follow the 'simple' set up wizard and also using the connect checklist at xbox.com and still no luck. when I press connect in the dashboard, it runs through the setup firstly confirming the cables were connnected then the setup ends and I get the metwork error message, this is where I now go aroung in circles. The connect status states the following:
    1. Cables connected
    2. IP not confirmed.
    3. DNS not resolved
    4. Xbox Live not found
    Please help because I want to be thrashed by some gobby 12 year old septic at HALO 2!!
  2. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Best as I can recall, it doesn't work too well with crossover cables. There's no way you can just plug it in directly?
  3. dunks517
    dunks517
    May 22, 2005
    4,003
    +513
    no, I just have a bleeding usb modem so my options appear to be limited!!
  4. dunks517
    dunks517
    May 22, 2005
    4,003
    +513
    I followed the advice given by a gamer on Xbox.com and a rather pleasant fellow by the name gave me the address to his website which is: http://www.xbox.live.btinternet.co.uk/. I was connected straight away!!
    Thanks for all other posts and advice. :clap:
    Gamertag: Combat Clerk
  5. MacReady
    MacReady
    Jun 25, 2003
    2,464
    3
    Barnsley, South Yorkshire
    +198
    Glad you managed it...I tried for weeks to use Live via ICS on my PC without success and ended up just buying a combined modem/router :mad:
  6. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Your USB modem doesn't have any other ethernet ports? Mine has 4!!
    Glad you got it sorted anywho
