Xbox live connection
Discussion in 'Xbox Forums' started by DSA244, Sep 20, 2007.
  1. DSA244
    DSA244
    Jun 15, 2007
    19
    My friend asked me the other day if he can connect to xbox live without a PC, but wasn't sure of the answer.
    He has just taken up a sky package where he gets free broadband and wondered if he could just connect a router to his line and then connect his xbox. Does anyone know if this would work, or do you have to have a PC.
  2. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    You can connect the xbox direct to the router with a cable or get a wireless adapter for the xbox and connect to a router that supports wireless.
    Both options work well.
  3. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    if he has a router then a pc/mac is not required at all
    as stated, simply plug an ethernet cable from the xbox into the router (it comes free with the 360 premium)
    or get the wireless adapter
    however, if his sky box and xbox are next to each other, chances are, the telephone socket for the router is there too
    therefore, the ethernet cable would be a much better option
  4. DSA244
    DSA244
    Jun 15, 2007
    19
    Cheers for that, a good money saver as I thought he would need a pc
