xBox live connection problem and homeplugs
aphemia
Hi there
I've always had my xBox connected via wireless adapter to my Netgear router. I haven't had too many problems except for the connection dropping occasionally. My router is quite far away from my xBox.
So, I decided to buy a pair of Comtrend Powerline homeplugs...
I've set them up this evening but I can't seem to connect to xBox live.
When testing the connection I can connect to the Network and the Internet, but the final (but crucial!) Internet-xBox Live bar is failing.
I've tried everything I can think off but am getting a little frustrated now...I've spent the last couple of hours browsing around the internet looking for a solution but no luck so far....
Does anyone have any bright ideas??
Rich
aphemia
Hi there
Rich
Occasionally I'm getting a message on the xBox 'Test Connection' that indicates there might be an issue with my MTU setting. The xBox is saying it needs to be a minimum of 1364, the router is set to 1458....:confused:
aphemia
No worries. I have the manuals...but no joy.
I'm going to reset everything and try again this afternoon...
