Xbox live connection help
Discussion in 'Xbox Forums' started by SNICK, Sep 6, 2004.
  1. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    I've finally decided to go down the XBox live approach, but I'm well confused :rolleyes: with the connection required. I have a broadband set up to my PC (Tiscali) - but want a direct set up, rather than through a router.
    However - my current ASDL modem only has a RJ45 input not an output (which is USB type). Can I get a cable with a USB output plug one end, and a RJ45 on the other, to connect to the xbox???? - Or will I need another modem for this purpose whichg has RJ45 inputs and outputs?
    thanks
  2. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,937
    2
    Manchester
    +4,457
    You'll need to run ICS (Internet Connection Sharing) on your PC, and connect your Xbox to your PC by Ethernet. See if this site helps. :)
  3. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    what type of modem do you have are you sure its input only as mine sounds the same setup and i have no probs with this for live I use usb for pc and rj45 for my XB
