Xbox live conection problem
Discussion in 'Xbox Forums' started by Bobole62, Jul 5, 2003.
  1. Bobole62
    Bobole62
    I`ve got xbox live with bt broadband running through a netgear dg814 router. while playing on line my connection keeps stopping. This happens every hour and a half or so.
    BT have said there`s no problems so I was wondering if anyone else has had any problems or possible solutions?
  2. zap
    zap
    May 19, 2001
    261
    U.K.
    +3
    Upgrade to the latest firmware for the router. I had the same problem. I am using a Beta version which I found in the forums at www.adslguide.org.
