Xbox Live at work
Discussion in 'Xbox Forums' started by twicenightly, Jul 11, 2003.
  1. twicenightly
    twicenightly
    Hi all,
    I'm getting broadband at home in a few weeks, but at the moment I'm very keen to sign up for Xbox live.
    Do you reckon I could take my Xbox to work, plug it into the network and sign up for Xbox Live?
    If I can do that, then when I do get broadband at home, will it automatically update to my home settings or do I need to change anything?
    Thanks in advance for any help.
  2. alcolepone
    alcolepone
    i have had 2 different setup on my xbox live, both home adsl.
    had no problems connecting with either.
    really is so very easy, just plug in turn on, and wait for the amchine to do its bit, if theres problems it will tell you.
    cant see why setting up in work and then moving to home would be a problem.
    good luck
    p.s. nickname is alcolepone on live
