Xbox Live and ZoneAlarm
Geordie Jester
Anybody out there know how to configure ZoneAlarm to allow Xbox Live access. ?
I get the feeling its blocking a required port or something. Any way to persuade (the freeware ver) Zonealarm to not block ?
Sinzer
You will need to make the IP address a trusted host, I think you can do this in the the advanced settings.
Get the IP address off the X-Box, go to the settings section there should be any area to allow traffic from connected PCs etc.
Sorry I am really sketchy on the details but it has been ages since i used Zone alarm and I am at work.
I can have a look when I get home.
Sinzer
Ahhh found it on my version.
Firewall > Zones tab > Add....
Select the IP address option and put in the X-Box IP it should be listed as a trusted IP.
Now try Live if you still have problems you will have to set the trusted zones IP settings to low.
Hope this helps.
Sony A90J & A80J OLED and X90J & X95J BRAVIA XR TV Line-up & Features: Sony Interview
