xbox live and NTL
Discussion in 'Cable TV & Virgin Media TV' started by simon69, Oct 25, 2005.
  1. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    I had an interesting conversation with NTL, apparently they do not support xbox live anymore and was told to contact xbox?????????
    I was hoping to get an xbox 360 and use a wireless connection, anyone use NTL and xbox live? any tips or suggestions?
  2. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,545
    83
    Somerset
    +184
    I use xbox live and a ntl cable modem - no problems.
  3. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    how have you got it set up?
  4. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    When they say they don't support it, they mean they won't help you set it up.
    But don't worry that's what we're here for :)
    I've got Broadband via a set-top-box, this goes to my wireless router,
    and I'm happily running 2 x PC's an Xbox a PS2 & wireless laptop without problems
  5. fabbers
    fabbers
    May 19, 2004
    128
    +10
    I don't think they've ever supported it unless you were on there 'more expensive for exactly the same' gaming package
  6. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,545
    83
    Somerset
    +184
    You can either use ICS (internet connection sharing) on your PC, your cable modem has to be plugged into the back of your PC. Or have a direct connection going from your XBOX to your cable modem. I haven't managed to getting working any other way, but I would assume a router with dynamic NAT out would work (that is to say any outbound traffic from the router looks like it is coming from the router external interface - i.e. the cable modem).
  7. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,963
    2
    2
    Manchester
    +4,475
    I use NTL. AFAIK, they have never 'supported' Xbox Live as such, but this doesn't mean you can't run Live on it however. It just means if you get connection errors, NTL won't help you sort it out.
    I have mine set up connecting the modem (got a seperate modem, as opposed to the set-top boxes they do - I'd recommend this method, it's easier as far as I can see) with a Linksys wireless G router, and my main Xbox is wired into this, and my secondary Xbox runs off wireless downstairs. Both of my Linksys wireless products - router (WRT54G) and gaming adapter (WGA54G) - are Live certified, so it's basically plug in and go. I didn't have a problem setting it up or connecting to people, it all works fine.
  8. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I have NTL and Xbox live, no problems at all.
    I can connect the Xbox directly to the modem but I use a router so that I can use the pc and PS2 online with minimum fuss too.
  9. Rob20
    Rob20
    Jul 3, 2004
    3,291
    +785
    I think I remember NTL charging an extra £5 for a XBOX live service. I have XBOX live going through an ntl BB connection. Just simply connected it to the BB modem. Also have a wifi - router allowing 4 ethernet devices to be connected along with wifi devices.
