Xbox Live and ICS on XP
Discussion in 'Xbox Forums' started by Sam, Jan 29, 2003.
  1. Sam
    Sam
    Nov 6, 2000
    329
    Surbiton
    +9
    I've just ordered Xbox Live and am planning to use the ICS technique to share my connection to the Xbox (I've got a PCI ADSL card and one of those plug n play USB to ethernet port adapters).
    Problem is that when I follow the instructions to allow ICS on XP from the xbox website (http://www.xbox.com/uk/live/howto/xp/) I don't get the options that are shown there.
    It says to click on LAN properties, but I don't have a LAN connection, all I've got is my ADSL connection in there and there doesn't seem to be anywhere that allows you to share the connection.
    :confused:
    Can anyone let me know where I am going wrong?
  2. Squiffy
    Squiffy
    May 23, 2002
    11,869
    Ashford, Kent
    +5,138
    I'm not sure as I haven't used ICS, but do you have to "bridge" the two network connections?
    I.e. your ADSL connection, and your ethernet connection?
    When I was installing my ADSL modem router XP kept trying to "bridge" various network connection types together.
    I hope this is of some help.
  3. justy101
    justy101
    Sep 5, 2001
    165
    Wem, Shropshire
    +17
    No need to bridge connections. Just go to your dial up screen. Select your main (only??) connecton. Select properties, then advanced tab, tick ICS and select the network card the xbox is connected to (switch xbox on) windows xp will then setup the connection including opening the ports through the firewall.
    Hope this helps
  4. Sam
    Sam
    Nov 6, 2000
    329
    Surbiton
    +9
    All sorted now cheers.
    Was trying to do all this without my network card installed, thus the ICS option didn't appear on my ADSL connection. :eek:
