Xbox light gun 480p argghhhhhh !
Discussion in 'Xbox Forums' started by ted26, Jul 10, 2003.
  1. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    I have just purchased the mad catz light gun for my xbox :) But in the instructions it says that it wont work on LCD monitors,HD(except 480p),projection,or line-doubler televisions :confused:
    My xbox is connected to my plasma(panny 5) via svhs so i think this is why i am shooting blanks :laugh:
    Would i be right in saying i need to connect my(chipped pal)xbox via component so it runs at 480p?
    I have done a little research and it seems i need the xbox high def pack which will then make the xbox run in 480p mode.
    thx for any replies :)
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,613
    3
    Nth Hampshire
    +1,019
    A standard UK xbox wont run 480p mate. Also I dont think a lightgun will work with a plasma but I dont mind being corrected.
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,613
    3
    Nth Hampshire
    +1,019
    oops..sorry mate, just read your post again and noticed you have a chipped machine. You will need to get a videomode disc to change modded xbox into NTSC to allow progressive but need someone to confirm if gun will work with a Plasma.
  4. RobbieG
    RobbieG
    Apr 3, 2003
    146
    28
    +32
    Light Guns do not work with Plasma TVs as I found out when I upgraded to my Plasma. I have had to stop playing my PS2 gun games whiched pi**ed me off a bit
  5. ted26
    ted26
    Apr 10, 2003
    511
    yorkshire
    +6
    but the instructions say it will work on HD if run at 480p ??
    Does this not include my plasma :( .First it was haunted castle 3D and now its the light gun grrrrrrrrrrrrrrrr
    Thx for help everyone :suicide:
  6. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    I have a similar problem. I bought the Thrustmaster lightgun for the Xbox as it is supposed to be 100Hz compatible.
    Doesn't work with my Loewe Aconda set though.
    Three out of five shots are on target, the other two are miles out.
    Anyone else had a similar problem with other 100Hz TV's and this model of lightgun.
  7. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    perhaps just fire faster?:confused:
  8. gunrock
    gunrock
    Apr 3, 2003
    132
    The Burbs, London, UK
    Can you disable the 100hz mode? That's the best way to test whether the gun is inaccurate. Who knows what extra noise is added to the image through the varios algorithms applied to make it 100hz.
    Personally, it's the reason I've haven't bought a new tv or a plasma. Still sticking with my 4:3 33-inch Ferguson.
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,150
    Sampling display devices introduce a timing mismatch between what the gun "sees" and what the playstation is outputting. Its a well covered phenomenon. Lightguns and plasma , LCD, scalers, deinterlacers 100Hz tvs don't work.
  10. Argento
    Argento
    Do any of these guns work with a Panasonic front projector? AE100....
    Just wondering.....
    Rich
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,150
    I'd put money on that being a negative for the panny ae100. Like I said anything that samples the signal coming out of the console prior to display will likely render the lightgun useless or unreliable.
