Xbox & LCD ?
Discussion in 'LCD & LED LCD TVs' started by vicsalt, Jan 14, 2005.
  1. vicsalt
    vicsalt
    Any one using an Xbosx with the philips 32PF9986. Im looking to buy an LCD but my friend who is a Manager of Chantry TV says he tried his Xbox on a lcd and says it was ****.
    He advised buying a Plasma. I dont really want to. Any out there using a Xbox on a lcd please advise
  2. drphibes
    drphibes
    Oct 23, 2002
    1,116
    48
    +33
    I can only presume you friend did not have his xbox setup correctly or he had some dodgy cables.
    I have 2 xbox's running on a Sharp 32GA3E and they are great.
    Both are run via the component socket, my modded xbox can output progressive scan and looks excellent and the unmodded box still looks good.
    The lead I use is the official HiDef kit from liksang.
    Drphibes
  3. deadred
    deadred
    Nov 18, 2004
    2,545
    71
    Cumbria
    +90
    I've got my Xbox hooked upto to an LCD and it looks brilliant, although i have to feed it through the RGB to get the best quality
  4. TAHIR
    TAHIR
    Dec 13, 2002
    33
    I have the X-Box, PS2 and Gamecube running on my 32WL48 LCD and the picture quality is brilliant, and I'm only using RGB scart for XBOX yet.
  5. vicsalt
    vicsalt
    Thanks, i was almost going to buy a plasma. So lcd it is
