Xbox 'Kung-Fu Chaos' widescreen prob - solved!
Discussion in 'Xbox Forums' started by Mark Spanner, Apr 13, 2003.
  1. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Just got my copy of 'Kung-Fu Chaos' on the xbox & have had a strange new problem. :confused:
    The game is in 4:3 & I have a widescreen TV:
    what was happening was the xbox was actually moving the picture off the screen to the right (cutting off some of the picture.)
    I have never had this with any other 4:3 game I have!
    But there is a solutiion - change the xbox to output in 4:3! :thumbsdow
    Because I have a widescreen my xbox is set to output a widescreen signal if possible.
    I'm assuming that this is either the xbox getting in a tiss (unlikely as I've not had the prob before) or some dodgy code in the game maybe?
  2. jerkyboy
    jerkyboy
    I had the same problem with this game, wierd !!.
    If you set your xbox to PAL 60 it sorts the problem out.
    The game flicks into Widescreen, with the picture dead central.
