Xbox in one hand, soldering iron on - help!
Discussion in 'Xbox Forums' started by nicnet, Nov 9, 2004.
  1. nicnet
    nicnet
    Oct 15, 2004
    3
    OK, so i'm still tyring to get a Logitech driving force pro steering wheel to work with an xbox. I've read the discussion about USB... xbox won't do it... silly 'cos it's basically a PC... and then somebody mentioned rewiring with breakaway cables.
    Well what I can't do with a soldering iron ain't worth knowing, so i'm up for a bit of DIY.What exactly do I need to do?
    I'm armed, hot and ready to go!!!!!!!!!!!
  2. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    go to xbox-scene and there should be a tutorial on how to rewire the five wire usb on the xbox to four wire usb (its simple).
    Rich
