xbox in my car
Discussion in 'Xbox Forums' started by the_Geezer, Aug 15, 2005.
  1. the_Geezer
    the_Geezer
    Aug 12, 2004
    467
    +26
    Hi to you all
    can anyone help me with any info on getting my xbox in my car
    taking it apart is no problem for me and can i use some sort of touch screen to make it work
    also any idea's on the turning on and off from the drivers seat :lease:
  2. cra41g
    cra41g
    Are you planning to hire a driver to drive your car whilst you play your Xbox!! Mental, but smart idea!! :smashin:
    Anyway, the guides listed in the link below may shed some light. You can find out from these where you need to connect your external switch to.
    http://www.xbox-scene.com/tutorials.php?p=191|241|#241
    When you're up and running, post some pictures if you can!
    Good luck!
