Xbox How big is the hard drive?
Discussion in 'Xbox Forums' started by muppetmick, Mar 21, 2003.
  1. muppetmick
    muppetmick
    Nov 11, 2002
    84
    over the rainbow-way up high!
    I have just started to compile a sizeable "jukebox " of my favourite music on the xbox.The quality I must admit is pretty good.So far I put down 80 tracks and the xbox memory still states that I have 50000+ blocks still available.
    So does anyone know exactly how much music I can store on the machine?
    I have done a search but could not find an adequate answer.
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I think it's 8 gig.
    I think the amount of memory it tells you is approximate. Basically it goes down 'in chunks', if you like.
  3. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    The 50000+ will only start to go down when you begin to run out of room. So basically you can put on what ever you like until you start to see that figure change, then you need to be a bit more choosey, even though you still have a fair bit left. I've about 1000 mins of music on mine at the moment and have not breached the 50000+ mark yet.
  4. GJC
    GJC
    Mar 1, 2002
    2,136
    London
    +69
    muppetmick
    Shame you cant switch the fan off the Xbox to enjoy listening to it
    IMO the CD/Music replay via the Xbox is a non starter, yes it allows you to rip music, and for some the replay will be acceptable. But, if anyone is serious about ripping music dont bother replaying it via the Xbox.
    Fan noise destroys the experience.
    Oh an extra set of audio outs and an optical out would be nice too. But then that might be too much to ask as it costs £150.
    Xbox is excellent for games. Lets leave the gimmicks alone unless its done proparly.
    GJC:devil:
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Course some of us have 120gb drives in our Xboxes!
    Speeds up loading times enormously!
  6. Azrikam
    Azrikam
    Sure, the XBox is loud, but the beauty of it is that the controller cords are plenty long, so you don't have to sit right in front of it. Also if your sound system is incabable of drowning out a fan, then maybe it's time to get a new system. :laugh: (or maybe a set of headphones)
    I've got optical out on my advanced scart, and it cost me about £20. I never use anything else.
  7. GJC
    GJC
    Mar 1, 2002
    2,136
    London
    +69
    azrikam
    I prefer to use remotes:D
    True, I could plug them into the Xbox - Doh no I cant!:rolleyes:
    Good for games - and not much else.......IMO
  8. Cloudnine
    Cloudnine
    I had my hard Drive go out so i took it apart and found a 8MB Drive.
  9. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    8 GIG !!! ;)
  10. Cloudnine
    Cloudnine
  11. Azrikam
    Azrikam
    Also, I think a section of the Hard Drive is off-limits to the user, and it just used for system settings, drivers, etc. 2 GB, I believe.
  12. Dom H
    Dom H
    the newer ver 1.1 xboxes dont have a fan on the gpu.
  13. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    my xbox has a 120 gig drive go figure;)
  14. Luker21
    Luker21
    Ive got a spare 20 gig hard drive lying around is it easy an safe to install it. I really dont wanna do in the machine as i just had it repaired. details would be appreciated. Also do i have to do something to the drive first?
    Thanks,
    xblgamertag: Luker21
  15. Luker21
    Luker21
    i cant find any info on this on the web very easily. Anyone?
  16. Jason S
    Jason S
