Xbox higher definition kit, and scart side adapter, but no cables in between plz read
Discussion in 'Cables & Switches' started by serial45, Jun 3, 2005.
  1. serial45
    serial45
    May 20, 2005
    248
    Liverpool UK
    +17
    Hi guys, basically I have this adapter [​IMG] and this plug to plug in TV side [​IMG]
    (the reason being my TV has no direct composite in connections, it is only possible through the av1/av2 scart sockets).
    But I have no cables to link the two together, (as the xbox higher def kit was given to me). Would any cables that fit both sides of each adapter fit the bill?
    OR do they need to be special leads that can process hi-def?
    Sorry for my idocy regarding this, but better safe than sorry :).
    THanks in advanced btw.
  2. John
    John
    Dec 13, 2002
    11,283
    +2,894
    Any phono leads will do the job.
    If I was you my main concern would be " Does my TV accept component into scart" . RGB scart is different to RGB component .
    Have you modded your Xbox ? If not , you would be better off with the MS scart lead
    atb
    JS
  3. serial45
    serial45
    May 20, 2005
    248
    Liverpool UK
    +17
    Hi man, thanks for speedy reply :)
    Sure yep I have a modded xbox,
    My options on my TV allow me to select mukltiple options for my AV options including Y/Pr/Pb, Y/Cr/Cb, RGB, RGB Scart and S-Video so tv supports it np :).
  4. John
    John
    Dec 13, 2002
    11,283
    +2,894
    Should be cool then
    John
  5. busterdan
    busterdan
    Aug 18, 2004
    1,346
    48
    SE London
    +37
    Yes Serial...any Phono's will do with the adaptor... or save that for your DVD player and get the Vivanco, all in one cable (in the Tevion cable thread)...that will set you back a tenner if that guy on Ebay has many more.
