Xbox high definition pack is it any good
Discussion in 'Xbox Forums' started by haujobbz, Jun 9, 2003.
  1. haujobbz
    haujobbz
    Jun 9, 2003
    2,259
    UK
    +172
    I was thinkin of gettin1 to use on a plasma screen but are the benefits significant over conventional inputs ie:svhs scart
  2. hencole
    hencole
    No point getting it really unless you have a US Xbox or a chipped PAL one. The standard PAL Xbox doesn't output in progressive. Your better of sticking with RGB SCART.
  3. Jason S
    Jason S
    Even if you have a standard PAL Xbox, the picture quality from Component is far better than an SVHS connection, sharper, better colour definition etc.
    It's better (IMHO) than RGB scart, and depending on the plasma panel you may not have that connection type (may require a tuner box)
    I'd recommend it, over the advanced AV pack / RGB Scart.
  4. zAndy1
    zAndy1
    Nov 26, 2002
    21,997
    2
    5
    163
    +8,432
    Agree with Jason , it's the best method of connection to a plasma so you should use it if possible.
    Andy
  5. dj898
    dj898
    You will love Xbox on PDP via component!
    It looks so good - PDO, DOA3 and DOAXBV looks amazing!
    dj
  6. Matravers
    Matravers
    Jan 26, 2003
    184
    16
    north london
    Will the high def pack work with an standard uk xbox though, and how do you set it on the dashboard as currently there is only RGB?????
    I am also buying a plasma and want to connect xbox via component as it should be an improvement, can you confirm it is worth having over Advanced RGB scart
  7. Jason S
    Jason S
    Just plug it in and it works
    Yes, it is better than the RGB scart into a plasma as you don't need to do any conversion via a tuner box or convertor and it feeds in at the highest possible input type.
    I had mine before I chipped my (PAL) X-Box and I was amazed at the difference in clarity between the two.
  8. De|ta
    De|ta
    where do you get the HD packs from in the UK - ive been looking but cant find them
  9. Jason S
    Jason S
  10. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    I have a new Official Hi-Def kit spare. It's not boxed because it came out of a special edition Xbox but is still sealed in polythene and has the leads that come with it..
    £22.50 incl recorded post.:) (guessing around £2.50 post)
  11. De|ta
    De|ta
    u sure thats the HiDeg - the SE xbox (green one) wasnt sold in the USA so theres no reason for it to have the hidef in there
  12. Oddbodd
    Oddbodd
    Apr 7, 2002
    1,154
    Sunny Tyneside :)
    +88
    Hi Steve, if that is a pukka microsoft hi-def. (component) kit you have I'll take it please.
    Cheers Oddbodd.
  13. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    yes mate it is official..it didn;t come with a UK machine, it came with my nice White japanese Panzer Xbox (bit I already have hi-def kit so it's spare. At least it offsets the cost of the machine.;)
  14. De|ta
    De|ta
    ahhh - i didnt realise it was on of *them* special editions, nice :)
