Xbox high definition cable.
Discussion in 'Xbox Forums' started by karlak, Nov 4, 2005.
  1. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    The High Def cable for the xbox - Does it come with all the cables attached or is it possible to replace/extend the Component leads?
    Am i correct in thinking that there are 2 types of cable? I am only talking official Microsoft cables BTW.
  2. Dar
    Dar
    Jul 9, 2002
    102
    Balbriggan
    +6
    Yes you can replace the component leads. I did this when I mounted my plasma on the wall and used a 3 metre component cable.
  3. John
    John
    Dec 13, 2002
    11,724
    +3,426
    yep . there are now 2 sorts of cables available ,one with fixed and one with sockets allowing you to substitute your own length . An email to your chosen supplier would help find out which one the have in stock
    atb
    john
  4. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    The official High Def Kit I have is a standalone box which you can plug any component/Audio/Optical leads you want into, you also got a set of componet leads with it. You are indeed right that there are 2 types of official MS cables as my mate got a set recently and they were moulded into the plug which is a more attractive/space saving option but is useless is you want to add more expensive or longer component leads.
  5. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    cheers guys -
    The problem is that I have ordered one and it has arrived as the 'fixed' component/phono sockets. The main problem is that it will be difficult to feed the cable down any sort of conduit, or the cable management behind the TV. The component cables are only 20cm long as they come out of the fixed block :(
  6. mal60908
    mal60908
    send it back and get the other one.
  7. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    Thanks guys! Wish me luck - Bought it on Ebay :( Although the description does say that the component cables are replaceable.
  8. smashed
    smashed
    Feb 7, 2005
    2,795
    +166
    The kit doesnt come with the optical cable though does it ? Cheers.
    Im sure I had to buy mine seperately
  9. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    That is correct NO optical cable.
  10. smashed
    smashed
    Feb 7, 2005
    2,795
    +166
    cheers
  11. fallenangle
    fallenangle
    Oct 19, 2005
    404
    +23
    I'm getting a TV with component connections. I can get the official XBox HD pack from lik-sang.com but what I want to know is if it's worth it?
    Can I use it with my PAL Xbox and if so how do I enable a PAL game's prog scan option, if available? Will it really give better quality than RGB SCART?
    If I use it with my modded PAL machine and NTSC games will it work/give me the option to select prog scan and if so how?
    Any other help/info much appreciated.
  12. shadybrady
    shadybrady
    Sep 1, 2005
    153
    Isle of Man
    +20
    If you have a modded pal xbox there are two ways to get it to output high def - either download the enigmah video selector which allows you to change your output to ntsc and then high def.
    Or some xbox 'dashboards' such as unleashx have hd support in the menu options to allow you to change the video output.
  13. fallenangle
    fallenangle
    Oct 19, 2005
    404
    +23
    Thanks.
    As it happens I recently installed Enigmah after not realising I actually needed it to be able to play NTSC games on my modded XBox :oops:
    So with Enigmah I should get the prog scan options offered by whatever NTSC game I'm using. Yes?
    What about PAL games can I access/use any prog scan option with these on either machine? How?
  14. Pooon
    Pooon
    Dec 26, 2002
    7,580
    Canterbury, Kent
    +1,232
    forget the pal/ntsc game thingy, its the video output that determines whether or not you can get prog-scan. the video output on your xbox dashboard needs to be set to NTSC and with a HD pack connected the option to select 720p and 1080i will become available
  15. fallenangle
    fallenangle
    Oct 19, 2005
    404
    +23
    Understood - thanks.
    Any opinion on the prog scan versus RGB SCART quality issue? Will I really notice a significant jump in PQ?
  16. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    Quick question :
    I see that different games work at different HD resolutions. Does this mean that you need to set the XBOX to the resolution of the game being played? Or just pick the highest option available?
  17. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    It all depends which of the three resolutions you have set in the Xbox's options. If you have set 480p, 720p and 1080i then the game will run at the highest resolution it supports automatically.
    For example MX Unleashed supports all three so it will run at 1080i as my Xbox is set output all of them. If I were to set the Xbox to output only 480p and 720p then the game would run at 720p. You can't choose the resolution you want from within the games.
  18. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    Thankyou
