XBox hi-definition cables
Ramspeed
Established Member
Hi all
I bought some cheap component cables (don't know the make) for my xbox and I'm getting trailing/ghosting @ 480p/720p (480i is okay). I remember reading on this site that this was a common fault with 3rd party leads.
I found the official cables @ www.mx2.co.uk but they're out of stock. Another website has IXOS cables for the same price. IXOS are generally a seriously good company for cables. Should I go with them or play it safe with the official cables?
Munkey Boy
Wtach out as some 3rd party leads don't have an optical out, like the official one does. Not a problem if you don't want 5.1 though obviously. I've never heard a complaint about the official leads.
Member 55145
dont go for MX2, they are ***** they charged my card then said they were out of stock, i said cancel so they did, 3 weeks later the cable turned up in and the plastic box was ripped open, i rang them up and said i told them to cancel, sent it back got a refund but it was all agro for nothing, their cable was the crap one too, get the official one from lik-sang i got it and its fab :thumbsup:
yorkshire rose
Established Member
rampseed,
i had the same problem, i was using a gamester version of the high def kit, changed to the official one. The sharpness is incredible especially on fifa 2006 @ 720p.
Colgate7110
Established Member
Ol!ver said:
Anyone got a suggestion as to where I can get the official cable from that's based in the UK? Could order from liksang etc but want it ASAP.
You could do worse than Divineo. A couple of guys in my work have used them for mod chips and so on in the past without a hint of a problem. It's £24.95 which is pretty much the going rate and it ships within 24 hours!
http://www.divineo.co.uk/cgi-bin/div-uk/xb-of-hidef
White Dog usually stock it but they are out just now with more stock expected on Thursday apparently:
http://www.whitedog.co.uk/catalog/product_info.php?products_id=626
Cheers,
Colin
richard plumb
when I tried some cheap 3rd party cables, I got green bands on my projector at 480p. Is that crappy cables, or a sign that I have a dodgy Xbox?
i.e. will it be a waste of time to get MS cables?
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
