xbox hi def
Discussion in 'Xbox Forums' started by thekingbeyond, Jul 27, 2005.
  1. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,661
    oxfordshire
    +347
    Just bought the microsoft hi def pack, but can`t get it to work, i have a softmodded xbox running evo-x, when i connect the hidef pack up i dont get a picture at all, will it only display a picture with an ntsc box, i cant enable 480p, 720p with the composite cable as they are greyed out and cant do it with the hidef pack because i cant get a picture :mad: :( :rolleyes:
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    HDTV is supported only on NTSC Xboxes so you need to use the Enigmah Video Switcher application to set your box to be NTSC then the HDTV resolutions will becoemavailable.
  3. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,661
    oxfordshire
    +347
    so you dont get any display at all through component untill you switch to ntsc
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    Correct!
  5. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,661
    oxfordshire
    +347
    Just used Enigmah Video Switcher to switch to ntsc no problem, however still get no picture from the hidef pack, i do get sound from it though.
  6. imilne
    imilne
    Oct 3, 2004
    524
    28
    +70
    Wrong.
    I had an unmodded PAL xbox that quite happily outputted component (using the Microsoft hidef cables).
    Iain
  7. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    King - sounds like you've got a faulty lead. Is it one of the new type ones or one with the breakout box so you can use your own component cables?
    imilne - thats right you should get a picture but it will only be a standard interlaced picture which looks just the same as it does with the advanced scart
  8. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,661
    oxfordshire
    +347
    i have the one with the break out box, i know its not the lead, i am not getting any picture so looks like its going back, thanks guys for the advice
