Xbox hi-def - Xecuter pro
Discussion in 'Xbox Forums' started by Jazz Monkey Jr, Jun 6, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,054
    2
    4
    137
    Garstang, Lancs
    +1,596
    I chipped my xbox a while ago, I think it was executer 2.2 pro. I have never used it cos I have been on xbox live.
    I would like to get a hi-def kit for it as I will be getting a new plasma soon. I had a few probs trying to flash the BIOS when I did it so I gave up, it has got a parallel cable thing on the back.
    What do I need for hi-def, how do I flash it etc...
  2. Cowden_harley
    Cowden_harley
    Jun 6, 2005
    4,646
    FIFE, SCOTLAND
    +217
    all you need to do is - get a hi-def kit, get a way to get a game save on your hard drive (via action replay or max drive etc) and a game that relates to the game save as well as a videoswitch file.
    I.e. - Splinter Cell (the original game) and a game save for it. load the game save when you start the game and theres and option to change the video settings.
    there are firmer details if you search on xbox hi def you'll find it. if you need anymore help give me a shout.
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,054
    2
    4
    137
    Garstang, Lancs
    +1,596
    Thanks for that
