Xbox Hi-def: X2VGA vs Component
Discussion in 'Xbox Forums' started by mark88, Oct 28, 2004.
  1. mark88
    mark88
    Oct 25, 2004
    878
    +23
    Is there a great difference between the two? The LCD tv i've got my sights on has DVI, VGA but no component inputs.
    I also wondered whether not using the proper xbox hi def kit will cause problems with the resoltutions settings in the dash?
  2. Shahel
    Shahel
    vga looks better then component and the M$ dash is a bit funky in HD mode as it wasnt made for HD for some funny reason (im running vga on a pw6)
  3. Kaz
    Kaz
    I'd second VGA looking better. As for the dash I only go into the MS one to change video settings (for the HD). It's very pink, but just about viewable.
