XBox Hi-Def Pack
Discussion in 'Xbox Forums' started by marshallp, Jul 7, 2004.
  1. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    I've just bought an Xbox off eBay and want to connect it up to my Plasma using the Microsoft Hi-Def Pack. I've read lots of forums that talk about changing the dashboard.
    I'm not that bothered about changing the dashboard; I just want to get the best picture quality possible.
    Any suggestions would be welcome!
    :thumbsup:
  2. peve3
    peve3
    Aug 14, 2002
    438
    Is you Xbox PAL or NTSC ?
  3. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    PAL, it's also chipped if that make a difference?
  4. peahead
    peahead
    Dec 14, 2002
    2,997
    St.helens
    +384
    get the enigma video selector software and switch that xbox to ntsc to enable the hidef modes its :laugh: well worth it.
  5. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    As above, definitely get the enigma to enable high def modes then sit back and enjoy. I have the high def mode enabled on my xbox and the picture via my pj is stunning :thumbsup:
  6. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    Chipped = awful. I'll swap my vanilla box with you to prove it ;)
    Can I ask how much you paid for it, as I'm after the same. Thanks
  7. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    £230 inc shipping with 55 games!
  8. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    Legit games, or games on the HD?
  9. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Thats a silly question isnt it :rolleyes:
  10. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    Yep, pretty stupid - sorry :)
  11. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    IF you want premodded I would go to your local computer fair. Thats where I got mine done whilst I waited. It wasnt expensive. I think I paid Around £100 for the upgrade which included the switchable chip, 120gig hd upgrade, new dash and all the fancy software, XB media player for streaming video files and mp3 over network, hd game loader, region free dvd etc etc etc.
  12. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    No, I got all the media!!!!!!!!!!!!!!!! it's only got the standard size HDD at the moment!
  13. loadsofleads
    loadsofleads
    Anybody having banding issues with their Hi-Def enabled Pal Xbox. I have tried two different component 'boxes', many different component cables (I now have IXOS cables worth £60 :eek: ) Even though the picture is much better in most ways, there is very faint colour banding vertically down the entire screen. You have to strain your eyes to see it, but it is there. Anybody else seen this, or any ideas how to remedy it. I have it connected to a Hitachi 5200, maybe it's an ALIS problem :rolleyes:
  14. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Is that a plasma screen or projector. I dont have this on my ae500 projector at all I am afraid using the standard ms high def pack.
  15. coolsurfer
    coolsurfer
    May 2, 2004
    37
    If you've got a 32 inch wide screen and want better pic quality which cable do you need to buy?
  16. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Well unless your tv has component ms rgb scart is about as good as you can get I think.
  17. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    As Harrisuk as said if your tv has component then definitely the m$ high def pack which is component, if not then rgb scart.
  18. coolsurfer
    coolsurfer
    May 2, 2004
    37
    Thanks for the info guys. Do you know where to purchase the RGB scart? Is this a different scart cable to the one I got in the box (AV to scart adapter thingy)?
  19. Slickeeboy
    Slickeeboy
    Jun 17, 2004
    71
    11
    +3
    Ok! Well I just learnt something. If I put the Enigmah software into the drive of my PAL x-box and select NTSC THEN go back to the dashboard I should be able to select the HD settings yeah?
    One other question. If I put my x-box into NTSC HD mode do British games running on the machine look any better?
  20. Hitcher
    Hitcher
    Jul 6, 2003
    68
    11
    Eastleigh
    Yes, as long as you've got the Hi-Def cable plugged in you'll see 480p, 720p and 1080i in the video settings of the official dashboard.
    Yes, nearly all PAL games will run in 480p and look gorgeous.
  21. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Can I just say if any of the mods are reading this. We really need an xbox high def sticky. So many points get raised again and again, I think it would be useful based on the number of people discussing this topic ?
    Just looking at the console category there are currently three threads near the top of the page discussing this topic and this is certainly not unusual....
  22. Kramer
    Kramer
    Mods read everything :zonked:
  23. Kramer
    Kramer
    How about a sticky thread where members can find answers to all their hidef questions? :p :smashin:
    Shouldn't take too long to write a post with all the basic info required...
    :smoke:
  24. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    There is a thread by neil mcrae with basic info already, i was thinking of a simple one where all questions could be asked in one thread rather than making lot's of threads about the same thing. what do you think?
    (Deleted my post by mistake) :blush:
  25. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    Yep, I suggested this just over a week ago (and I expect others had before) as like all newbies, I was repeating Hi def questions.
  26. DDRUK_Lawrence
    DDRUK_Lawrence
    Apr 29, 2004
    37
    Has anyone tried switching a PAL box to NTSC using enigmah then switching off Xbox, disabling the mod chip and then connecting to Live? There has still been no definative answer on this. If there is no checking going on for appropriate region and Live is just checking the bios is the actual MS one then this would mean you can play on Live in HiDef from a PAL box set to NTSC. Thoughts....?
  27. Hitcher
    Hitcher
    Jul 6, 2003
    68
    11
    Eastleigh
    That how I've been playing on Live with my modded PAL Xbox for about a year now.
    There's no video mode check and it would be stupid, I my opinion, for M$ to ban someone for wanting to get the best out of their Xbox.
  28. Slickeeboy
    Slickeeboy
    Jun 17, 2004
    71
    11
    +3
    Cheers for the info Hitcher.
    I presently have two x-boxes, one "special" one, and one "normal" one for playing on LIVE!! I'm being extrmrly hopeful here but does anyone know if ther is any way whatsoever you can change video mode on a non modded machine? Bit of a long shot really but I thought I'd ask......... :rolleyes:
  29. Hitcher
    Hitcher
    Jul 6, 2003
    68
    11
    Eastleigh
  30. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Yes as Hitcher said there is a "soft hack" for xbox. I have a friend whos box is modded in this manner and I can confirm that it works.
