xbox hi def on pw7
Discussion in 'Xbox Forums' started by sylence, Apr 27, 2005.
  1. sylence
    sylence
    Dec 28, 2004
    35
    hello
    i been searching the net but cant find a definate answer for my problem.
    can i use hi def settings on my 37pw7? i know my screen does progressive scan but its not hidef compatible(sky hidef compatible). i will be getting my xbox chipped for this feature on friday if it works. i have a component board and will order the hi def lead from liksang soon. is there anything else i would need for this to work?
    thanks
    anthony
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,499
    London
    +995
    You'll be able to display a 420p image on your plasma which I'm sure is better than what you have at the moment.
  3. sylence
    sylence
    Dec 28, 2004
    35
    thanks for the reply and yes it is better than i get at the moment.
  4. geewhizz
    geewhizz
    Jan 2, 2005
    2,402
    +84
    I have nearly the same: pw7 42" modded xbox ( xecuter 2 chip ) slayers evox.
    Now i have my xbox going into a sony dav sc5 home cinema going into a pro v
    www.keene.co.uk/cgi-bin/bigcodesearch.pl?PV200
    Then to plasma via vga cable.
    So will i benefit from getting hi def leads and i will also need a component board.
    Talking about £120ish all in, will i get a better picture than i get just now or will it be of similar quality ( which i think is really good just now ).
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,499
    London
    +995
    geewhizz - You're better off asking some of the guys who have already got their hi-def soft mod to work. Whilst I have seen the difference it makes (which is a vast improvement over my scart jobbie!) I don't know how much of an improvement it will make to your current vga connection.
    Maybe somebody else has tried this?
