Quantcast
XBOX Hi-Def Kit
The_Wierd
I have a cheapo component cable for my 'box. I fancy getting the official HD kit for better quality and just wondered if anyone can confirm what is included in the package. It looks to me on the website like I need to get a set of component leads as well as the kit, or are these included.
TIA folks.
D
daveymacca
I've tried using an expensive set of component cables with the official high def kit and they make no difference compared to the ones straight out of the box. The main advantage of the Microsoft kit is the picture quality is much higher than the 3rd party efforts.
M
monsta2003
ive tried the ms pack and the gamester pack, ms pack destroys the gamester one. MS one definatley worth the money.
