Xbox hi-def kit?
Discussion in 'Xbox Forums' started by Kramer, Dec 5, 2003.
  1. Kramer
    Kramer
    Does this also offer optical output?
    Doesn't seem to indicate so & can't see anything else bar the official MS kit. Is the MS kit the only choice?
    Ready to go "big screen", just need the hi-def kit.
    Your assiatance appreciated.
    :smoke:
  2. hOwLa
    hOwLa
    The cable you are looking at does not have an optical out - I was gonna get one but I would have to fit a optical port to my Xbox which is no big thing but I thought it would be better to use the official cable in case anything goes pear shape. I have just got the MS HD Kit today and it has Component out, Stereo out and optical out for connecting to your amp. I got mine from www.mx2.co.uk for £29.99 but it took 2 weeks to get here!
  3. Kramer
    Kramer
    Yep, noticed M2X doing the official kit but £30 :eek:, not cheap it it :D
    Found it a little cheaper than that somewhere but haven't dealt with them before.
    No cheaper options?
    Cheers.
  4. Kramer
    Kramer
    OK, going to go with this.
    Looking forward to 8' gaming :)
  5. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,473
    London
    +83
    just what i was looking for!
    cheers mate.
  6. Kramer
    Kramer
    & less than £20 delivered :clap:
  7. Kramer
    Kramer
    Just went to order (had to find my login details) to find:
    Back to the drawing board :(
  8. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,473
    London
    +83
    just ordered one as well
  9. alfienoakes
    alfienoakes
    Oct 31, 2003
    333
    46
    Kent
    +116
    I recently ordererd one of these from Lik-Sang. It's just under the £18 mark before shipping, so should avoid any customs charges. Delivery was about 10 days using the cheapest delivery option. Direct Link
  10. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,477
    Chesterfield town of the crooked (Spire)
    +72
    Don't panic cables are universal :smoke:
  11. Kramer
    Kramer
    It arrived yesterday. Pretty good, just over a week from order to receipt.
    Got it from here, approx £24 delivered.
    :smashin:
  12. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
    lol,ok,it looks like a few of you have ordered various kits listed above so which 1 would you reccomend the most(must have optical)
    Cheers:smashin:
  13. Kramer
    Kramer
    The one I've linked to is the "official" MS hi def kit/pack as used by most here AFAIK.
  14. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
  15. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    That's the one.
  16. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    It states on the site =
    High definition AV pack for all Xbox consoles (Except PAL). Offers component and AV out plus optical out.
    Is this true? Or will it work on my Pal Xbox?
  17. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    It will work on your PAL Xbox if it is modded and set to output NTSC. They are correct it will not work on a a PAL box becuase a standard PAL box will not output HD. Hence the need for it to be modded and set to NTSC output with the Video Select disc.
    BTW, Yamaha only has one 'm' :)
  18. Kramer
    Kramer
    It should still output 525i on a "standard" xbox ;)
  19. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    Messiah... You need to be a little more specific there fella.
    The High Definition AV kit WILL most definitely work an a virgin UN-modded PAL XBox. It will quite happily output component video.
    However...
    You will NOT be able to use any video mode other than 575i. That is, while the high-def AV pack will work on a PAL console, you are limited to standard PAL interlaced video output. All the high-definition modes (480p, 720p and 1080i) are disabled and you must have a mod-chip to access them, as Messiah pointed out.
    I bought an official high-def pack and it worked fine on my virgin XBox. Then I modded it, and was able to access the progressive scan modes that are available to NTSC XBoxes only.
    There is a significant improvement in image quality even when using a High-Def pack on a standard PAL console.
  20. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    Sweet, thanks peeps. Im gonna order one. Bit of a shame I only have one set of component inputs on the TV, can anyone recomend a sloution so I don't have to keep switching the leads?
  21. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I've posted on this loads of times! I use this video switcher: http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?SVS14. Everyone always says "it's just a video switcher", but I know for sure it works. I get progressive scan from my DVD, (chipped) Xbox & US Gamecube all coming through this.
    Edit - The link doesn't work. Go to the site and search for "4 WAY S-VIDEO & AUDIO MANUAL SWITCHBOX". That'll find it.
  22. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    The link finds no products!
    Edit = Cool just seen your edit!
  23. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    Willy did you notice any loss in quality?
  24. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Sorry, meant to say that before. No, none whatsoever. I'm only using a 32" TV so maybe it doesn't hold up so well on something like a projector screen, but I've not noticed a drop in quality on my TV.
    This solution was originally recommended to me by someone on the old Edge forum, and I've been recommending it myself ever since.
  25. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    Nice one cheers, ill give it shot. Does it have Scart and S-vhs input\outputs too?
    Edit = Don't bother just read it for my lazy ass self :eek:
  26. Teleport
    Teleport
    Correct Link
    http://www.keene.co.uk/cgi-bin/codesearch.pl?SVS14
    BUT This only seems to do S-Video not component
    The search continues...
  27. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    Dam, I need component switching.
    Dogh!
  28. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    I use the component video switching in my Yamaha 630 amp. It's only got 2 inputs tho. If you were upgrading your AV amp it's an option.
    'proper' component video switchers can be very expensive
  29. DpM
    DpM
    Jul 15, 2003
    4,272
    High Wycombe, UK
    +813
    Not gonna upgrade for at least 2 years.
  30. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    No, it does do component. This discussion has been done hundreds of times on this site before. I cannot say it any clearer: it does component.
