xbox hi def and dvd playback
Discussion in 'Xbox Forums' started by kennyb, Jul 23, 2004.
  1. kennyb
    kennyb
    Apr 29, 2003
    58
    scotland
    does playing dvds through xbox with hi def pack give you 720p 1080i ?
  2. dgordon
    dgordon
    Hi kenny. The answer is it depends. With the standard DVD software....No I don;t think so. With DVDx2.0 (requires modded box) I know the answer is defintely no. Media center is supposed to however I have difficulty getting it to play DVD's at all so currently I can;t say much on that but maybe somebody else has it working fine in which case I am sure it will output to 720p at least
