xbox help
Discussion in 'Xbox Forums' started by jason t, Jan 17, 2005.
  1. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    hi is it possible to play back dvd's at a higher resolution i.e 720p ??
    i have a modded xbox,high def pack and video switch disc do i need anything else
    thanks
    jason
  2. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Xbox Media Center will do it.. not too sure on the results myself as I don't have anything that'll accept 720p but I have heard good results.
  3. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    i didnt want to use that it sounds to complicated
    jason
  4. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    In which case other than using another piece of software of a similar ilk (and complexity) I think you're limited to at best 480p (and even that's not straight forward) output from your box.
  5. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    dosent using the enigmah region disk enable hi def settings?
    or is that only for games??
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    put the region switcher on a dvd/cdrw and load it up in the xbox (presumably you know about burning xbox compatable disks). Then, when the disk has loaded you press either A or B (I can never remember) to enable NTSC mode. Once this has done, remove the disk and reboot the xbox. Now boot into MSDashboard, once here go to settings, then video. Now enable 480p and 720p (and possibly 1080i although there is not much point in the last one) and reboot.
  7. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    thanks !! i assume i can play movies in 720p from here is that right??
    jason
  8. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Whoa there - enabling 720p only works for games - the MS Dash will still only play DVD's interlaced at 480 unless it is patched.
    That's my understanding of it.
  9. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    i read that if you have the xbmc installed you can upscale movies !! i just wondered if there was an easier way?? if it outputs the games in 720p using the switcher disc why cant it upscale movies?
    jason
  10. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    If only everything in life was that simple. The 720p games are coded as such, however the Ms Dash DVD system is not coded to upscale - it just isn't physically possible.
    XBMC is the only way to go to get DVD's in 720p I'm afraid - unfortunately XBMC has only limited DVD menu compatibility at the moment as well.
  11. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    Yes, XBMC has no dvd menu playback at all! :p
    It is a talked about feature of AVA-Launch but not introduced yet....
    However, at the moment, as andrew says, XBMC is still the only upscaling xbox DVD player.
  12. jason t
    jason t
    Mar 4, 2001
    1,569
    48
    kent
    +38
    thanks
    jason
