xbox help please
Discussion in 'Xbox Forums' started by terryshep, Mar 27, 2002.
  1. terryshep
    terryshep
    Mar 26, 2002
    215
    +6
    Hi can anyone tell me if the uk xbox does progressive scan i bought the high definition pack and set the menu right but any game that is 480p doa3 comes up with no single but sound works it not the tv as its a plasma tv and the dvd player work in pro scan ?
    witch makes me think the uk progressive scan is not working on the uk one .
    any help please
  2. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Firstly, i think that 480p is the NTSC standard, PAL is 525p are there any other settings? can you change to NTSC and 480p, or PAL and 525p.
    I am looking to take advantage of the component output but only interlaced as will go via my scaler. Have you tried interlaced? ie 480i or 525i ???
    What happens with a DVD?
    Hope this helps...........
    Nathan
  3. terryshep
    terryshep
    Mar 26, 2002
    215
    +6
    hi the dvd player is pioneer dv 737 and that plays 480p ?
    the plasma tv is th 42pw4b and that can display all pro scan modes
    i delive that the uk xbox has had the hight definition dissabled and microsoft hotline wont give me a answere
  4. museumsteve
    museumsteve
    Jan 28, 2001
    7,982
    4
    Nth Hampshire
    +1,094
    no progressive on UK Xbox..:( tried everything. Maybe there will be some kind of hack or something in the future., You do have to wonder hwy you still get an option in the dashboard when you connect a hi-def kit. I mean if it's something that was left in for the sake of it then why doesn;t it also give 720p and 1080i like the US machine.?
