Xbox help on PD7200
Discussion in 'Plasma TVs Forum' started by Miander, Jul 16, 2005.
  1. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Hi peeps
    I have just tried my Xbox on the PD7200! and its well not working right.
    it using the standard scart
    Xbox is chipped
    Av1 on composite. and i have ran all through the colour modes! and nothing gets rid of the fuzzy black and white picture!
    I will geta HD kit soon... but not just yet!
    Has anyone got any ideas !
  2. VSC
    VSC
    Mar 3, 2005
    25
    3
    Sounds very much like your plasma or your x-box is set to s-video signal, and the other a normal composite signal. Try the menus on your plasma for something along the lines of 'av input'.
  3. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    nope makes no diff, not having any luck! : :lease:
  4. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Is your xbox set to NTSC video mode?
    If so, try the Pal setting!
    Dr.
  5. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Xbox is on Pal and it wont let me change it!
    if i flick through the settings i can get rid of the fuzzyness (setting to PAL-N0 on AV1) but its still black and white!
    Im trying to use AV1 with the standard xbox scart connector!
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    AV1 will only allow you to use composite or s-video, not RGB.
    Don't know if that helps at all, I know nothing about consoles.
  7. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Tried it in every socket i can and get the same thing!
  8. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Can anyone help? i need to play FORZA! :(
  9. david 4 fingers
    david 4 fingers
    Jan 27, 2005
    169
    +5
    if im not using my i def kit i run my xbox thru the s-video plug(av5) in the remote socket on the side of the 7200,it free's up the scart sockets and its a better picture quality.
    what software is installed on your modded xbox????have you got the enigma video mode switcher??it changes from pal to ntsc at the press of a button.
    hope this helps
    David..............
  10. junpit
    junpit
    I have mine plugged into AV4 from an official hi def kit and it works fine. I would suggest getting a hi def kit from www.lik-sang.com and using that.
    If you can get hold of the enigmah video mode switcher utility, you will benefit massively from the hi def cable. You should just switch the box to NTSC using this utility and then yo should enter the dashboard.
    Going into video settings opens up some options for stating if your TV supports 480p, 720p and 1080i. These options are only ebaled for NTSc as MS did not think that european users would want HD as its wasn't that popular when the xbox was launched.
    Almost every xbox game on the planet plays in 480p and they look amazing in this mode. Switch all 3 modes on and you won't regret it. Once you have run the enigmah utility, you can switch you mod chip off and even play on live in these modes (providing you have originals of course).
    The xbox uses RGB scart and hence will not work with AV1. AV2/Av3 will be fine with you scart lead. Are you using the scart lead you got with the box? If so (I'm trying not to be patronising) check that the yellow lead is plugged into the yellow port on the scart connector. People sometimes get these the wrong way around and it causes all sorts of problems.
    -Junpit
