Xbox help B/w picture on PD7200 Plasma
Discussion in 'Xbox Forums' started by Miander, Jul 16, 2005.
  1. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Hi peeps
    I have just tried my Xbox on the PD7200! and its well not working right.
    it using the standard scart
    Xbox is chipped
    Av1 on composite. and i have ran all through the colour modes! and nothing gets rid of the fuzzy black and white picture!
    I will geta HD kit soon... but not just yet!
    Xbox is on Pal and it wont let me change it!
    if i flick through the settings i can get rid of the fuzzyness (setting to PAL-N0 on AV1) but its still black and white!
    Has anyone got any ideas !
  2. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    Does it only produce a b&w picture on another screen/tv? can you disable the chip? the fuzzyness could just be the nasty composite cables that are supplied with the xbox when displayed on a large panel this could happen. get a HD pack asap
  3. semiskimmed
    semiskimmed
    Jun 30, 2005
    4,962
    Nottingham
    +242
    try changing it from svideo too, maybe in the menu.
    i get that sometimes with my xbox, just have to flcik through the inputs to get the colour back.
    also see if theres anything in the menu's about it.
  4. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Hi thanks!
    yeah i have been through what i think is every config... it isnt BW on my 32" Sony Wega!... just on this
    I can turn the Chip off but i am unable to find the Bits for Turning the HD modes on..
    I will be getting a Kit but it seems real strange that it just wont play in colour!
    getting real anoyiong now
  5. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    only use component with yoru xbox 2 plasma.
    use the hi def pack for the xbox
