Xbox hdtv problems
Discussion in 'Xbox Forums' started by cleverdave2k, Nov 19, 2004.
  1. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    Hiya wondering if some one can help me i got a modded xbox with a x3 in.Ive set it to ntsc and have enabled hdtv in the x3 live menu but im still failing to get a picture up for my dashboards i have got a modified m$dash for when the chip is on and the original when the chip is off.I can play games ok if loaded straight up with a 480i picture and get the xbox logo before my modified m$dash loads up any one got any ideas or can give me instruction via button presses how i can enable hdtv without actualy seeing the picture thanks in advance :thumbsup:
  2. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    just to add im using the official hdtv kit connected to a infocus x1
  3. allanp
    allanp
    Jun 28, 2004
    1,062
    63
    +108
    I think the dash only supports 480i.
  4. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    If you click both triggers and both thumbsticks it enables progressive in the NTSC dash.
  5. cleverdave2k
    cleverdave2k
    Sep 25, 2004
    438
    28
    +39
    Thanks the trigger treat worked a treat for my original dash :thumbsup: i dont think me modified one takes hdtv though :(
