Xbox HDTV on Pioneer 435XDE.. PLEASE HELP??"?"
Discussion in 'Plasma TVs Forum' started by moopa, Jan 26, 2005.
  1. moopa
    moopa
    Hi all,
    Having quickly read about making modded PAL xboxs run in 480p 720 etc I ordered a lead very quickly. Today it came and I excitedly plugged it in. Alas no picture on the component input (input 2). I then read about changing to NTSC via the svideo input. This I managed but on reboot no pic. Can the Pioneers run HD on the component input? Am I doing something really wrong?
    Any help would be greatly appreciated.
    Thanks in advance
    Dave
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    You need a MODDED XBOX.
    Run Enigmah Video Switcher app, available on Slayers EVOX 2.6 disc. Switch to NTSC. Goto Standard MD Dashboard, say YES to 480p/720p/1080i. Reboot.
  3. moopa
    moopa
    Already did all of that.
    Nothing :(
    I can see the picture through svideo only.
    Modded Xbox - Enigmah on NTSC. ALL Set to yes. Xbox in input 2 of the reciever.
  4. moopa
    moopa
    Ok realised what it was.
    You have to select component in the optiosn menu of the reciever as it is defaulted to video :)
  5. moopa
    moopa
    Ok I do have another problem though. I am putting the audio left right into the inputs below the component ones and I am getting no sound. Any ideas?
  6. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Are those not outputs? (Don't have a 435 just a 434)
    In my setup, any audio coming in over Scart is routed through these audio outputs which are then connected to my AV amp.
    For XBOX, I take the Digital Optical output from my Hi-Def box straight to my AV amp.
    I know that the 435 has an optical output but suspect this only carries the sound from the Digital Tuner, as I suspect Pioneer have soley integrated their Freeview box into the Media Receiver.
    i.e. The Optical Output will not route SCART inputs audio.
