Question Xbox HDR & Sky 10bit problem
Discussion in 'General TV Discussions Forum' started by hassesbar, Oct 7, 2018.
  1. hassesbar
    hassesbar
    Aug 11, 2006
    46
    11
    +4
    Hi there,
    Just got a Pana 65FZ802. Connected to Sky Q and Xbox 1x through a Yamaha a3060.
    All with latest firmware and updates.
    I’ve got two issues
    1. Sky a says there is a problem when trying to run 10bit, but 8 bit works.
    2. Xbox says tv can’t display hdr10
    Tried differed settings for a few hours but nothing solves it.
    Any help would be much appreciated.
    Many thanks,
    Chris
  2. zeppelino
    zeppelino
    Jan 24, 2018
    3,053
    134
    UK
    +827
  3. next010
    next010
    May 29, 2005
    10,728
    163
    +2,097
    1) Make sure firmware on the Yamaha is up to date.
    2) On Yamaha check that 4K HDR is enabled, see page 155 of the manual, you have two modes if 1 does not work try 2.
    3) Your cable that connects the yamaha to the TV may not be up to the task and cant handle the bandwidth, should be a premium high speed HDMI cable.
    The Xbox is scanning the receiver not the TV for resolutions/features support, thats why it says there is no HDR support.
