XBOX HD settings - Where?
Discussion in 'Xbox Forums' started by thebigkung, Sep 9, 2004.
  1. thebigkung
    thebigkung
    Hi all
    Trying to get my Xbox setup for HD on my plasma.
    I have a PAL modded Xbox
    I have switched it to NTSC via the enigma video selector disk. The plasma confirms this has changed.
    Can't find the mode settings (480p, 720p....etc). Have checked under settings in the video menu and aill I get is a choice of Normal, letterbox or widescreen settings.
    I am waiting for my MS HD lead. Do I have to wait for this before the settings will show up on the xbox?
  2. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Yes, hi-def options only appear once high def output kit connected.
  3. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    If its a PAL xbox then your wasting your time, but yes you would still need the hidef kit and a component cable.
  4. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    An Leedavies has stated once you get the high def pack connected the options for 720p and 1080i will appear.
  5. thebigkung
    thebigkung
    Thanks, peoples. I'll wait for the lead.
    AML,
    >"If its a PAL xbox then your wasting your time..."
    Why is that? From what it've read as long as the XBOX's epprom has been set to NTSC then I have the output options (when I get the HD cable). The XBOX is modded so that it runs NTSC games and the Plasma will take any signal up to 1080i. (so essentially it is now an NTSC XBOX with UK power supply! :cool: )
