Xbox HD + PV500
Discussion in 'Plasma TVs Forum' started by Zeggi, Oct 21, 2005.
  1. Zeggi
    Zeggi
    Ok i remember seing somone posting about this before and im not sure if it was here, so il post about the problem and hopefully there is a fix.
    Ive got a xbox moded one with HD cableset, component and well i just noticed this on my projector 2weeks ago and now i notice it alot when playing movies on the xbox, while gameplay doesnt show it that much.
    the picture will show what i mean.
  2. steddyman
    steddyman
    Dec 25, 2004
    472
    28
    +28
    Did you buy the Microsoft Original Advanced HD cable from the states or are you using a UK bought cable?
    I had exactly the same problems with a component adapter from Toys'R'Us. I also got ghosted text on anything higher than 480p. The reason is the UK cables / adapters are only configured for PAL at 480p.
    I bought the official cable and the picture is orders of magnitude better. Even 1080i looks fantastic (must use NTSC mode).
    You can get the official cables from:
    www.lik-sang.com
    www.diveneo.co.uk
    Steddy
  3. Zeggi
    Zeggi
    Thanks alot!
    il buy one within the days to see :)
    thanks
  4. John
    John
    Dec 13, 2002
    11,724
    +3,424
    That looks how mine did on my Hitachi , before I modded it .
    It is a modded box , isnt it ?
    John
  5. Zeggi
    Zeggi
    yupp its a moded xbox, with pcbioxx
  6. John
    John
    Dec 13, 2002
    11,724
    +3,424
    You have run the enigma switch , and gone into the MS dash to enable the HiDef outputs . Always best to start with the obvious ;)
    John
  7. Zeggi
    Zeggi
    been there done that.... long time ago that is.
    ive placed an order on a hdpack from dvdboxoffice.com
  8. Zeggi
    Zeggi
    OK! now i recived my new hd cable from dvdboxoffice which is NTSC region 1 Usa and i have the same problem, also with my projector, anyone of you guys able to figure out whats wrong?
  9. John
    John
    Dec 13, 2002
    11,724
    +3,424
    Have you checked that the game your trying is HD compatable ? Most are , but sods law would dictate that the ones your trying are not .
    Double check the MS dash
    John
  10. Zeggi
    Zeggi
    its a normal dvd movie, games work perfectly
