XBOX HD & executer 2
Discussion in 'Xbox Forums' started by Wubble, Feb 12, 2005.
  1. Wubble
    Wubble
    Firstly... thanks for everyone who posts answers on this forum!
    I have a chipped xbox using an executer 2 with evoX installed, including the video switch app.
    I managed to buy a HD capable projector and want to enable the HD modes on my xbox.
    So far I have set the video mode to NTSC and rebooted the box, but I still dont have the additional video options listed in the MS dashboard.
    Any ideas as to what I am doing wrong?
    Ta
    W
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    To get hidefinition output from the projector, you must use a high definitiion compatable cable. For the xbox, this is VGA or Component. When you plug in a component pack or VGA pack you get the new options. You can either buy this high definition pack online http://www.lik-sang.com/info.php?category=83&products_id=1742& or from the person who sells them on this forum. The component pack should work out less than £20 and the component cables another £20 if you need a LONG run (www.tvcables.co.uk sell great value cables). But, I assure you, you will notice the difference!!!!
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    By the way: I linked to the official component pack because it is leagues ahead of unofficial ones in the quality stakes. For the sake of £5 it is easily worth it!!!!!
  4. Wubble
    Wubble
    Excellent! thanks for the reply.
    I didnt realise that one of the high def cables had to be physually attached before the extra options in the video screen appears.
    I will rectify that right away :)
