Quantcast
xbox has died- any ideas???
P
phetttt
Hello folks
Have an xbox about 4 years old now, ive replaced 2 dvd drives but now it wont switch on with the power button, only if you press the eject button. But it can cut out at any time. Any ideas? If I bought new xbox is there an easy way to transfer saved games etc (ive soft modded it using the spinter cell method). cheers
unique
Hello folks
you can get 2nd hand xbox from cex.co.uk for £35. you can go into your msdash and copy savegames to and from a memory card. you'll get one of them from cex for £6 if you don't have one
JeLLyMaN
You can also get MC's from eBay for 5.99 w/ shipping as well (Thrustmaster 8MB).
I'd say the PSU has gone if it dosn't boot up.
