xbox game saves
Discussion in 'Xbox Forums' started by dazap, Apr 23, 2005.
  1. dazap
    dazap
    Oct 21, 2004
    1,012
    shrewsbury
    +126
    can any one tell me if there is any way you can move saved games from 1 xbox to anouther
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Either use a lan cable to conect 2 machines, or use a memory card.
    Just save the file onto the card then plug it into the other machine.
