Xbox forgetting my gateway setting
Discussion in 'Xbox One' started by Stutto, Feb 1, 2014.
  1. Stutto
    Stutto
    Apr 20, 2007
    383
    28
    +53
    As per title, I manually entered the network info as I am using a DMZ to ensure an open NAT.
    I am having to enter the gateway every time that I boot up, it has been doing this for the past week.
    Anyone else?
  2. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    why are you worrying about this? open nat is all down to your internet provider, the second they start tweaking your internet is the second it will change to strict or moderate, other than that, it could be a router glitch solved by turning it off and on more often than not
