No Daz ,Does this controller come with a rechargeable battery pack like the plug and play kit ?
Cheer mate that just saved me £120 .No Daz ,
I already have a plug and charge kit for my normal controller so will that work ?Lol , that's logic for you , I already had one and use that for mine , it's a cracking controller though mate , I sat on the fence for a while before I got mine, so glad I did though
Well as you know I am pretty much unstoppable with a normal pad so buying the elite might make it impossible for anyone else to get a look in .Yeah it does mate ...go for it
Until you take your ball homeWell as you know I am pretty much unstoppable with a normal pad so buying the elite might make it impossible for anyone else to get a look in .
haha I don't even bother getting the ball out anymore mate .Until you take your ball home
Game strike again Daz , send it back get ,your money back and go with Amazon , they get stock in quite regularlySo the controller has just arrived and I am a little worried.
Everything seems brand new and the item was fully sealed before I opened it. All the manuals and cables look in pristine never been touched condition but the controller is covered in fingerprints and has a large white mark down the right hand side running from just below the A button down past the thumb stick.
Those rear paddles are already connected to the controller but there are empty slots in the case for them. The spare/extra parts are filthy and definitely look like they have been used.
This might have to go back.
Double tap the green button on the top of the controller to disable/activate the paddles if you keep catching them with your shovels DazSo after a few hours of gaming I already love this thing .
It feels amazing in my shovel sized hands and the weight is perfect. The thumb sticks feel really solid and don't have any travel in them like the normal ones.
The only meh I have is about the rear paddles but that quickly died when I got used to them. I now use them rather than the normal top buttons.
I have yet to configure the controller with the app so looking forward to that.
