Xbox dvi input
D
dan_wade
Im running my xbox with progressive scan through a device ive got some time ago. Things are working great. The standard connection is VGA from the device to my Ae500 projector. Ive seen a VGA to DVI lead though. Is DVI better quality than VGA?
Ive got a DVI input on the back of my projector thaat im not using.
Cheers,
Dan.
malcolm
I may be wrong Dan but simply coverting the signal from vga to dvi via a cable will not improve the picture quality.
K
Kramer
Yes, you'll only get VGA via DVI if you use a convertor (assuming DVI-I, "integrated", both analogue & digital).
Most DVI-VGA adapters are for DVI to VGA.
So, no "digital" DVI output available from the xbox.
:smoke:
65-inch LG C1 Review coming soon to AVForums
