XBox & DVDR-
Discussion in 'Xbox Forums' started by QED, Aug 3, 2004.
  1. QED
    QED
    Guys,
    This question has probably been asked before but I can't find it.
    Can the X-Box play DVDR-'s?
  2. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    If it is chipped then yes, if not then no.
  3. QED
    QED
    Cheers,
    I wont bother buying the DVD dongle and remote then!
    QED
  4. inzaman
    inzaman
    Dec 16, 2002
    7,887
    Derby
    +939
    It may be worth looking it getting it chipped as you can also play dvds without the remote or dongle.
  5. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    Doesn't it depend on what manufacturer made the drive for the xbox. afaik there are 3 different thypes of drive, and iirc one of them will play dvd-r and cd-r etc. there is a website out there that will tell you but i can't remember the address. try a google search with something like "which drive does my xbox have" and you should find it.
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    it doesnt need to be chipped to play dvdr movies, only dvdr games.
  7. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    this is true I play DVDR- on mine all the time and its not chipped but this is just movies not :lesson: games
