Xbox DVD
Discussion in 'Xbox Forums' started by evolution400, May 24, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Hi guys I am thinking of using my xbox as my dvd player in my spare room I know its will output dolby digital 5.1 and DTS but will it output DTS ES and Dolby EX ?
    I have an amp which does the decoding for both ES and EX.
    Thanks.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    All dvd players that output 5.1 will do ES/EX sounds as well as it is the amp that decodes the signal. It's kinda like pro-logic sound being buried in a stereo signal.
  3. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Thanks once again mate I thought so just wanted to make sure :)
  4. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    I have just got my new yamaha RXV450TI amplifier which supports 6.1 and the decoding of dolby EX and DTS ES however I have hooked it up to my xbox tested it briefly yesterday with starwars epsiode 2 whihc is definately dolby EX and no sound comes out to my rear centere speaker at all the rear cnter spekaer is not even lit up on the display yet when I do a speaker test using the amp it works ?
    Has anyone actually got a 6.1 system setup using thier xbox ?
    I have altered all the setting spossible on the amp the xbox is as it should be set to DTS and dolby to on mode.
    Thanks in advance.
  5. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    dunno whats up. i've used my xbox to wastch LOTR:TTT extended edition with the DTS:ES soundtrack and the centre rear was working just fine. i also have a Yamaha amp, but different to yours(mines older i think)
