XBOX DVD Output
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dirty Sanchez, Sep 28, 2003.
  1. Dirty Sanchez
    Dirty Sanchez
    Could anyone tell me how the XBOX DVD output compares to an expensive DVD player and if its worth buying a seperate 'more expensive DVD player' cheers
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,124
    Berks, England
    +45
    It looked a little pixellated to me when I borrowed a mate's DVD playback kit.
    It might be on on a 28 inch widescreen for most things though. What were you planning on viewing it with?
    cheers,
    Rob.
  3. TranceFan
    TranceFan
    Sep 9, 2003
    718
    43
    uk
    +173
    equivalent of I reckon a £60 quid player, although the Toshiba 330 for £80 will be sharper and overall smoother. Ok as an occasional player, and leagues better than ps2 dvd player.
  4. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,233
    116
    The Apps are Calling :-S
    +522
    I'm without my Sony DVD Player at the mo, and my Xbox has been a very acceptable replacement.
    The picture is not quite as detailed and a little softer, but just checkout the layer-change, what do mean you didn't notice?????;)
  5. Dirty Sanchez
    Dirty Sanchez
    Well to be honest my TV is pretty small compared to some of the monsters ive heard about on here! And I have noticed in the dark backgrounds when using the XBOX DVD you can see the pixels kinda 'jerking' about if you know what I mean, I presume that wouldn't happen on a decent player?
    What about the 5.1 sound is that any good?
  6. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Xbox isn't a very good DVD player to be honest. It has horrendous artefacting issues on dark footage. The £80 Toshiba is light years ahead.
    That said, I've patched mine to produce a progressive scan output, which did the job until I got my DVI-output Momitsu V880 :)
  7. quadophile
    quadophile
    Sep 6, 2003
    78
    11
    +4
    My son uses it and when we got it the first day we did an extensive comparision of the XBox with the DVD player and we were not very impressed. But we never bought the XBox for watching movies anyway so it does not really matter, if I had known I may have opted not to get the DVD kit though.
    XBox graphics are leagues ahead of PS2, the DVD playback on the PS2 was also not very good.
  8. Nick Laslett
    Nick Laslett
    Oct 9, 2002
    After Nov there will be a new PS2s that will be Prog Scan enabled with built in remote sensor.
  9. JUS
    JUS
    Jan 21, 2003
    3,174
    Plute
    +218
    I wouldn't consider using a console for watching films. Far too noisy.
  10. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Xboxs do vary in the quality of their output. The first and possibly second revisions used a high cost and high quaity video encoder i.c. but then Microsoft decided to change suppliers and went for a cheaper chip on later consoles. I'm sure a internet search will give you more details. However I think contrast was increased on later revisions to the early models (i.e. stronger signal).
    Also many of the dvd drives are detuned from the maximum reading ability to try to prevent CDR and DVD-r copies from working. This is meant to prevent piracy but also means these drives aren't brilliant loaders and if a dvd drive can't read a sector on a dvd you get artifacts on screen which is common on the xbox.
    Its a pretty low grade dvd player by any standard but does get the job done and of course chipped it gives you access to divx playing etc.
  11. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Well, it depends how you connect them up and what software you use.
    My Xbox is chipped and runnin DVD-X2 software with progressive scan patch and component vid cables to my Panny AE200 projector and the image is stunning.
    I actually bought a mid range DVD player with progressive output and the Xbox was much much better.
  12. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    I'm possible thinking of using a chipped Xbox to get progressive.
    Can you please tell me how easy it is use compared to a standalone DVD player. i.e. can you just insert a dvd and play?
    Also, how noisy is the machine.
    Azzo.
  13. vc820
    vc820
    Aug 5, 2003
    56
    My Xbox revision 1.2 (manufactured Jan 2003) compares very favourably to my Denon 2800 MKII (£750). I'm using an official Advanced Scart cable for output with the Xbox (RGB). The Denon is using Component output via a Supra AV3 and has a Russ Andrews Reference power cord attached. The differences? The Denon has slightly bolder colours, slightly better sharpness, slightly less artifacts and pixelisation and a slightly better contrast range. You notice I've used the word 'slightly' a lot in my descriptions, that's because that just about sums it all up. The Denon is better all round by in my estimations about 5%, which isn't a lot considering the price difference and of course you can play games on the xbox. Could I live with my xbox if I had to send the Denon away for repair. Most definately.
  14. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Well I tried my xbox for dvd movies connected to my ae100 using a microsoft component adaptor and the xbox set for ntsc mode. I was pretty disappointed with the results even with progressive. It seemed to lack contrast and region 2 titles played in ntsc mode looked awful but the setup didn't seem to like the xbox set in pal mode either. I bought a cheap £50 Compacks DVD5000 and it blew it away totally in image, sound, features and compatibility.
