Xbox DVD Kit Alternative??
Discussion in 'Xbox Forums' started by Gadget Daddy, Mar 10, 2005.
  1. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    Hi, Could anyone tell me if they know of a way to avoid the M$ DVD kit??, I know there a Sensor you can solder on but Im eally not up to that, the idea is I control my Xbox via my Harmony 659, or do I have to bu the kit and not use the cheesey remote or can you just buy an adaptor??
    Any advice appeciated
    Pete
  2. Pooon
    Pooon
    Dec 26, 2002
    7,568
    Canterbury, Kent
    +1,219
    I take it a Harmony 659 is a learning type remote. If so just bite the bullet and buy the dvd playback kit and 'learn' all the buttons from the xbox remote to the Harmony. Much simpler than getting a mod chip fitted.
  3. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,427
    83
    Stockton on Tees
    +174
    sounds like a plan does anyone know the cheapest place to get one?
    Pete
  4. Pooon
    Pooon
    Dec 26, 2002
    7,568
    Canterbury, Kent
    +1,219
    Play £15.99(but out of stock:devil:)
